thank you!
muhammed
Band: madtheory
muhammed
muhammed
Band: madtheory
recording db:-3-db.-5 db
muhammed
thank you!
muhammed
Band: madtheory
thank you again
muhammed
Solderman
Real name: Zane W
Gear: KARP Oddy, SEM Pro, SH-101(mod), Kraftzwerg I w/MF101, µBrute, TR606(mod), TB303, α Juno 1, CS-15(mod), Поливокс(mod), Virus b
Band: madtheory
Return to Sound Production
