Fairlight library with loop points!
Postby D-Collector » Fri Feb 28, 2014 10:34 am
First of all, this is NOT my doing. Someone has one-upped me, haha! But that's just great.
http://www.nattvard.com/iix/index.php
He's found a way of extracting the samples with both loop points and attack/sustain parameters (if the original patch have them).
To download each disk in full go to "database", under column "library/disk" click the link to the desired disk and a box will appear. Choose "Convert" and you get to download that whole disk folder with samples and SFZ (or akai s-900 if you desire) presets containing all parameters, and even a html page (screenshot) of Fairlights Page-7 for each patch. Neat!
On his site he even has an online program that can convert your disk images straight to the above, so if you are an IIx owner and have floppys with your own custom sounds this is golden! You can even convert wavs to CMI disk image, and there is an app to upload a .co file and view it on Page-7 style.
There are some patches that are great with original loop points, but there are a lot of bad ones too. And for some samples I have found seamless loops with Extreme Sample Converter whereas the original loop pops like h**l. But at least this appears to be the closest we have come to the original library on PC with most parameters intact.
Thanks Carl, for your great work on this!
D-Collector
Re: Fairlight library with loop points!
Postby synthroom » Fri Feb 28, 2014 4:27 pm
Carl's done a lot of work on this project - he's done a great job with it too!
synthroom
Real name: Kirk
Postby dustinh » Sat Mar 01, 2014 12:24 am
Thanks a ton for sharing this! I was just trying to find a good fairlight sample library or vst emulation last night and didn't have much luck other than a $200 plugin that I don't have the money for.
dustinh
Postby commodorejohn » Sat Mar 01, 2014 12:32 am
Sweet. Thanks for sharing!
commodorejohn
Real name: John
Gear: Roland JX-10/D-50/MT-32/SC-55k, Ensoniq SQ-80/Mirage, Yamaha DX7/V-50/FB-01/SY22, Korg DW-8000/MS-20 Mini/ARP Odyssey/M1/03-RW, E-mu Emax HD/Proteus/2
Postby madtheory » Sat Mar 01, 2014 12:47 pm
Very cool.
Band: madtheory
Postby seamonkey » Sun Mar 02, 2014 1:33 pm
I can't load either the WAV or the SF file into SFZ+.
Any idea what the problem might be?
I'm able to load other WAV sounds and SF sounds, so I know everything is working ok.
seamonkey
Real name: Rick
Postby D-Collector » Sun Mar 02, 2014 7:44 pm
Works fine in cakewalk SFZ player.
http://www.cakewalk.com/Download/sfz.aspx
D-Collector
Postby gmeredith » Mon Mar 03, 2014 1:09 am
This is worthy of being a sticky :)
I'll make it one, so look for it up the top from now on.
Cheers, Graham
gmeredith
Band: Warning Will Robinson
Postby madtheory » Thu Mar 06, 2014 3:40 pm
Kontakt only sees the wav file in the SFZ, no loop point or mapping- am I doing something wrong?
Band: madtheory
Postby synthroom » Thu Mar 06, 2014 10:39 pm
EMail Carl through the site - he's pretty quick with replies.
Kirk
synthroom
Real name: Kirk
Postby oberheim » Sat May 24, 2014 4:39 pm
Superb job! :)
[RO] SH101, D550, D-110 JV1080, MKS70, S750, S550 [KW] K1r, K5m, R-50 [AK] S700, S1100, [EMU] ESI32, ESI2000, Proteus 1 [KRG] EX800, X5dr, M3r, Wavestation SR, P3, Symphony, DW6000, DSS1, DS-8, Poly61, S3, DDD1, [NV] A Station, [OB] Matrix1000, [NRD] MicroMod, [YAM] TX7
oberheim
Gear: Lots of Korg's, Kawia's, Roland's, Akai's and Emu's. Plus a Yamaha, Nord and Oberheim.
Postby mpa1104 » Wed May 28, 2014 2:10 am
May I just say that I've really been enjoying these samples. Props to D-Collector for posting the link, to Carl for his tremendous work, and I'm guessing to the same "Kirk" from here who was thanked on Carl's page for testing the samples. Really great being able to hear and use these sounds from many a favourite 80s track! :) =D>
It doesn't matter if you don't like my personality, I have several more.
mpa1104
Gear: Finally, enough gear that exceeds the 150 character allowance. WooHoo - I qualify as an obsessed gear-head!
Postby synthroom » Thu May 29, 2014 4:37 am
Yeah, that's me. But I didn't really do so much other than give Carl a bunch of test disk images for him to work on. He certainly did a great job with this project and he put a lot of time and work into it!
synthroom
Real name: Kirk
Postby greggybud » Tue Jun 24, 2014 7:39 pm
madtheory wrote:Kontakt only sees the wav file in the SFZ, no loop point or mapping- am I doing something wrong?
This is what I have discovered too. I could easily be doing something wrong since I'm not very familiar with Fairlight, and even how Kontakt handles certain files.
Since Kontakt has almost become a universal format, could anyone explain what I'm doing wrong? Or maybe loop point and mapping is not possible with this library and Kontakt?
I read his FAQ and there is no reference for Kontakt users. I will send an email.
greggybud
Gear: DSI Polyevolver, Mopho
Ensoniq VFX-SD-2, ESQ-R
Oberheim OB-8, OB-12, M-1000
Moog Voyager
Nord 2
Yamaha TX-802
Roland D-550
Emu Morpheus, Vintage Keys
Postby madtheory » Wed Sep 03, 2014 4:44 pm
Did he reply?
Band: madtheory
Next
Return to Samplers
