Korg Delta CV Mod?
Korg Delta CV Mod?
Postby Honey Peters » Sun Jan 04, 2009 3:28 pm
Anyone know a way to modify the Delta to take CV in? It can accept gate triggers, but CV would be amazing (even if just on the synth portion)
hp
Honey Peters
Re: Korg Delta CV Mod?
Postby oryjen » Mon Jan 05, 2009 10:17 pm
I use a Delta for long and know it like my pocket.
I think it's not possible without adding a complicated interface, 'cause the Delta's a strings machine like an organ and doesn't work with a VCO, but with a fixed oscillator which's frequency gets divided into all keys frequencies.
It might be possible to electronically alter the results of the divisions, but that would make loads of chips and wires, cause you would to alter ALL KEY's frequencies.
I wonder if the Delta's case would contain all this...
However you would have a second problem to solve: The Trig IN doesn't feed the VCA but the VCF. So you couldn't trig the synth externally without lowering any key. :wink:
Korg MS20-MS50-SQ10-X911-SuperDelta-800DV-MP4-Lambda ES50-severely modded Poly800-PE1000-M500SP-Trident MkII-KPR77-DSS1-P61//EkoSynth P15//YAMAHA CS30-CP30-DX9-01V//RSF Blackbox x2//Viscount CL1-R64//SCI Multitrack-P600//Roland GR500-SH1000
oryjen
Postby Honey Peters » Tue Jan 06, 2009 1:23 am
Darn.. But that last bit explained some of the triggering problems I was having.
What is the difference then between the VCF FcM IN and The Trig IN?
Honey Peters
Postby Denms20 » Wed Jan 07, 2009 5:04 am
One's a control voltage in to vary the freq of the filter, the other triggers the envelope that controls that filter.
Hammond CV, M3, s6, Korg MS-20, SP-100, CX-3, Hohner D-6, Roland JX8P, Sound Canvas, Yamaha Tx7, Casio CZ101, Rhodes, Crumar T1
http://www.organdenstudio.com
Denms20
Gear: Korg MS-20, CX-3, SP 100, Roland JX8P, Sound Canvas, Hammond CV, M3, S-6,L-100 Rhodes , Wurly, D-6 clav, Yamaha TX-7, Crumar T-1, Casio CZ-101
Users browsing this forum: Bing [Bot] and 5 guests
