Who makes Volt/Hz modular synths?
Postby madtheory » Thu Apr 02, 2009 4:35 pm
I have a CS-5 and a CS-10 that I'm very fond of. I'd like to expand the palette with some modules. However, these synths are V/Hz. Which companies, if any, make V/Hz modules?
Band: madtheory
Re: Who makes Hz/Volt modular synths?
Postby meatballfulton » Thu Apr 02, 2009 4:44 pm
Nowadays, nobody makes V/Hz.
The gates will work to fire envelopes, you just won't get proper pitch tracking with V/oct modules.
Postby Stab Frenzy » Thu Apr 02, 2009 5:42 pm
Isn't one of the Paias Hz/V?
Postby novielo » Thu Apr 02, 2009 5:49 pm
paia does some, i remember that you could have it from the module or the fatman i don't remember wich one.
but i think mad wanted to use his synth directly to modules. not midi to hz/v on one side and midi to oct/v on the other to make them work at the same time
novielo
Gear: in order of appearence:
Band: one-man band
Re: Who makes V/Hz modular synths?
Postby madtheory » Thu Apr 02, 2009 6:57 pm
Yes, I want to add oscillators etc. to the Yamahas. Paia don't do V/Hz modules anymore. But the Fatman is V/ Hz inside.
Yes, I understand about gates, I'd really like to have conventional pitch tracking :) so V/Oct modules are not what I'm after.
Band: madtheory
Postby Mush » Thu Apr 02, 2009 7:07 pm
I think this might be interesting for you - just route it to your external signal input. I'm making a few for my korg
ms10 when the parts arrive and I get some time to do te soldering.
http://www.electro-music.com/forum/topic-32689.html
Cheers
Mush
Gear: I have all the gear I need.
Band: Mush Orchestra / Rasmus Nyåker
Re: Who makes Volt/Hz modular synths?
Postby cornutt » Thu Apr 02, 2009 7:09 pm
The Dotcom Q108 VCO has a linear FM input. I don't know over what range it could be made to track accurately.
cornutt
Gear: 6th
Postby GeneralBigbag » Thu Apr 02, 2009 7:09 pm
You want a Metasonix Wretch.
virb.com/ookpikk
GeneralBigbag
Postby madtheory » Thu Apr 02, 2009 7:14 pm
Very cool Mush, thanks :)
So does that circuit need an LFO fed in to get the PWM going?
Band: madtheory
Postby Mush » Thu Apr 02, 2009 7:23 pm
madtheory wrote:Very cool Mush, thanks :)
Yepp, but those are even easier to build and can easily integrated in the design. I prefer inputs and separate modules to integrated designs. One even easier solution would be to mod your CS's with an LFO-output.
Mush
Postby meatballfulton » Thu Apr 02, 2009 7:46 pm
Stab Frenzy wrote:Isn't one of the Paias Hz/V?
Old PAiA modulars (2700, 4700) were V/Hz, Fatman has V/Hz output only (MIDI in), 9700 is V/oct.
Postby madtheory » Fri Apr 03, 2009 11:24 am
GeneralBigbag wrote:You want a Metasonix Wretch.
Ah, thanks! That's the one I saw mentioned as V/Hz, but couldn't remember the name :)
I just checked the price... personally, if I had that kind of money, I'd get a Prophet 08... but that's just me...
Band: madtheory
Postby Stab Frenzy » Sat Apr 04, 2009 3:10 am
Ah, thanks for the clarification. :)
Users browsing this forum: Bing [Bot] and 9 guests
