Links to Free Samples in here!!!
Postby tallowwaters » Thu Jun 19, 2008 10:36 pm
Lots of Drum Machines (and some synths)
http://samples.kb6.de/downloads.php
http://machines.hyperreal.org/manufacturers/
http://www.hexawe.net/mess/200.Drum.Machines/
http://www.soundcentral.com/
Some samples from Movies
http://www.wavcentral.com/movies.htm
http://www.moviewavs.com/Movies.html
Samples from the Waveterm
http://www.ppg.synth.net/zip/lib_14_march_2001.zip
Sign Up!
http://freesound.iua.upf.edu
http://www.sampleswap.org/index.php
http://www.oneshotsamples.com/
Mellotron Samples
http://tinpan.fortunecity.com/aphex/113/
Links to other links/big open directories
http://www.stonewashed.net/sfx.html
http://www.dmoz.org/Arts/Music/Sound_Fi ... and_Loops/
Massive library with access to other massive libraries
http://www.sonomic.com/
Selling samples, but tosses out a few freebies
http://www.sonivoxmi.com/freesamplespage.asp
Soundfont
http://hammersound.net/cgi-bin/soundlink.pl
Various stuff
http://www.samplenet.co.uk/
http://hem.passagen.se/piplayer/samples/
Really nifty field recordings in MP3
http://soundtransit.nl/search/sounds.php
The Berklee College of Music, Berklee Music Synthesis Alumni,
The International Csound Community, Open Path Music and Avid Technology
have opened up their sound libraries to the children of the world - and to YOU!!!
http://createdigitalmusic.com/2008/03/3 ... s-torrent/
Here's hundreds of MP3 samples from the Alesis Andromeda.
http://www.wohmart.com/a6/audio/
tallowwaters
Gear: LC-MS/MS
Postby tallowwaters » Thu Jun 19, 2008 10:40 pm
Feel free to inform me of dead links and new links in this thread, I will update the main posting as needed.
Thanks to all who participate!
tallowwaters
Gear: LC-MS/MS
Re: Links to Free Samples in here!!!
Postby tallowwaters » Wed Oct 01, 2008 2:07 am
Sep. 30, 2008 - Updated - dead links filed out, new ones put in
tallowwaters
Gear: LC-MS/MS
Postby Jabberwalky » Sat Oct 11, 2008 6:21 am
Jabberwalky
Gear: P61 | Dw8k | 800dv | 700s | Sub37 | An1x | EPS16+ | Paia9700
Band: Variar, Model Human
Postby Stab Frenzy » Sat Oct 11, 2008 8:36 am
Machinedrum sampled by Suburban Bather, cleaned up and hosted by lost cause.
http://www.zshare.net/download/203101891b495573/
Thanks to both of them!
Postby aeon » Sat Mar 07, 2009 5:14 pm
I recently programmed a synth sound that could be described as a string ensemble. Not the sound of a string machine, but the sound of a group of strings - synthy of course. You might say it has the sound of a "strings" waveform in a ROMpler, but without the artifacts of too-short looping and/or dynamic compression such that it is smoothed-out and semi-lifeless.
The synth patch makes use of PWM for animation within the timbre. For thickness and the ensemble tone, I layered detuned oscs together.
I made a total of 21 samples from C1-C6, sampling every minor third, i.e., C - D# - F# - A, at 44.1KHz, 16-bits depth, in mono. This resulted in a sample set that was ~16MB in size - perhaps a little larger. If so, not using the C6 sample would be the easiest solution for a 16MB sampler.
The files are named as such:
nn_keynameoct.wav
where nn is the MIDI note number for key assignment (36-96), keyname is C, D#, F#, or A, and oct is the octave of the sample (1-6).
And yea, I am sharing them with you. :) Download them here:
http://rapidshare.com/files/198978380/aeon_strings.zip
You will need to assign these samples to a keymap and assign filter and amplitude envelopes so they properly play as "strings" would. Yea indeed, there is some programming work involved, minimal as it might be. That said, I hope you enjoy these samples and can put them to good use in your music.
Here is a quick demo courtesy of Yoozer:
http://www.theheartcore.com/music/aeon_strings_demo.mp3
Setup file for Logic EXS:
http://rapidshare.com/files/202438606/aeon_strings_EXS.zip
Setup file for Kontakt:
http://rapidshare.com/files/202438607/aeon_strings_Kontakt.zip
cheers,
Ian
aeon
--=< aeon's fairvoxmodel >=--
Postby aeon » Tue May 19, 2009 4:44 pm
I recently programmed a synth sound that could be described as an interpretation of the original Fairlight "arr1," or "sararr" sample - the classic female "ahh" with breath noise.
The sound is entirely generated via physical modeling synthesis - no samples were used in its creation. The environment used was the DSP of the Korg OASYS PCI.
My sound has less breath noise, and more glottal grit - but as I said, it is meant to be an interpretation of the original, not an emulation.
I prepared a total of two samples, both at 44.1KHz, 16-bits depth, in mono. Both are pitched at C4. One is longer, to achieve a less-noticeable loop, whereas the other is purposefully shorter, with a clickless, but noticeable overall short-loop. This is to achieve some of the timbral charm of the original and its artifacts.
Aside from some gentle compression, no effects processing was used in the creation of these samples. They are absolutely dry and raw.
Download them here:
http://rapidshare.com/files/234812391/aeon_fairvoxmodel.zip
The files within the .zip are looped AIFFs.
You will need to assign the sample to a keymap and assign filter and amplitude envelopes so they play as you want them to.
I hope you enjoy this sample and can put it to good use in your music.
cheers,
Ian
aeon
Postby hollowsun » Mon Sep 07, 2009 11:51 pm
Hi all!
I am new here (first post and all that) but if I may be so bold as to steer you towards hollowsun.com for a good few freebies in a variety of formats.
Enjoy!
Steve
hollowsun
Postby wertpog » Fri Dec 04, 2009 1:45 pm
I've recently put together a site containing free samples. There are a couple of sounds from the Waldorf Microwave, but for the most part it's analogue modular sounds, multi-sampled for polyphony.
All samples are available in EXS24 and soundfont formats (see the separate post for sf's). However, since the new version of autosampler was released, all new samples will be in EXS24, Kontact and Reason format.
http://www.modularsamples.com/
I'll been updating the site on a pretty regular basis, in fact I plan to add some samples of the DSI Tetra and Siel Orchestra 2 once I get my studio put back together.
http://modularsamples.com - (public domain samples of classic synths)
wertpog
Postby HideawayStudio » Mon Apr 19, 2010 9:55 pm
I've recently started making multisamples of my vintage samplers in action - these are taken directly from the instrument's mix outputs and hence their full audio path is present in all their glory! (ie. how it should be!!)
The 4th sample was made using a DIY tube osciallator I designed.
The Following are in Kontakt 3.5 Format:
Emulator II - Bosendorfer Piano:
http://www.sendspace.com/file/s2gkvm
Emulator II - Marcato Strings:
http://www.sendspace.com/file/vjat6y
Sequential Prophet 2002 Guitar Preset:
http://www.sendspace.com/file/kc38ue
My DIY Tube Oscillator - sampled:
http://www.sendspace.com/file/433m21
Enjoy!
HideawayStudio
Real name: Dan Wilson
Band: Shortwave
Postby nuketifromorbit » Sat Jan 01, 2011 6:25 pm
Anybody donate to kb6, are they trust worthy?
We'll always be remembered, we'll always be dismembered.
nuketifromorbit
Postby supermel74 » Mon Feb 14, 2011 4:13 am
supermel74
Postby smoothcriminal » Mon Feb 14, 2011 11:05 pm
Epic tanpura (drone) samples. Probably all the tanpura/shruti/harmonium samples you'll ever need.
http://www.ocf.berkeley.edu/~mrahaim/
http://www.karnatik.com/shrutibox.shtml
smoothcriminal
Real name: Matt
Postby daverose » Fri Aug 31, 2012 3:09 pm
daverose
Postby Sir Nose » Sat Feb 02, 2013 8:15 pm
Funkadelic wrote:nothing is good unless you play with it
all that is good is nasty
Sir Nose
Real name: Bob
Return to Samplers
Users browsing this forum: Bing [Bot] and 2 guests
