Yamaha CS30 VCA 1 problem
Postby radek tymecki » Sun Oct 11, 2009 8:24 am
I have little problem with my Yammy.
When i set VCF 2 volume to 0 I can still hear it. I don't know what trimmer should I use to get it proper working :(
here's service manual
http://manuals.fdiskc.com/flat/Yamaha%2 ... Manual.zip
radek tymecki
Re: Yamaha CS30 VCA 1 problem
Postby maindeglorie » Sun Oct 11, 2009 9:15 am
Check the INPUT switches on VCF1 and VCF2. Also check the INPUT volume knob.
This synth is definitely one of the most confusing layouts ever.
maindeglorie
Gear: Voyager Select,Little Phatty,ARP Solus,Omni II,Yamaha CS-40M,Prophet 5,Prophet 08,OB-Xa,MaxiKorg,Nord Lead 3,Nord Wave,Eurorack modular, etc.
Postby radek tymecki » Sun Oct 11, 2009 10:47 am
input is set to 0. works fine.
when vcf2 is set to 0 it sounds like 10. i mean it has proper volume. when i move the knob the sound gets louder.
radek tymecki
Postby Sir Ruff » Sun Oct 11, 2009 7:22 pm
Sounds like VCF 2 is still coming out of VCA 2 (which is where it's supposed to come out of). Set the balance slider to the "1" side entirely. with the VCF 2 knob turned down, you should hear only VCF 1 (if that knob is turned up).
Or, with the balance set entirely to the "2" try setting VCA 2 to envelope A -or any envelope that you're not using-and then have that envelope set to external trigger.... you should not heard anything then (as long as the EG/Hold switch is set to EG)
I don't think you have a problem, you're just not eliminating the signal fully. The balance slider is the easiest way to move between VCA 1 or 2, instead of trying to turn VCA 2 "off" (which again, is not actually possible unless you prevent it's envelope from opening)
If you can expand your original post with pics of the remaining layout, I could probably pinpoint the issue better, but I'm pretty sure it's just a case of not eliminating the signal.
Do you even post on vse bro?
Sir Ruff
Band: Ruff in the jungle
Postby maindeglorie » Sun Oct 11, 2009 8:07 pm
Sir Ruff wrote:I don't think you have a problem, you're just not eliminating the signal fully. The balance slider is the easiest way to move between VCA 1 or 2, instead of trying to turn VCA 2 "off" (which again, is not actually possible unless you prevent it's envelope from opening)
Forgot about that. See! This is what I'm talking about! :D
maindeglorie
Postby radek tymecki » Sun Oct 11, 2009 8:40 pm
ok so what should i do to hear for example 100% of vcf1 and 50% of vcf2?
radek tymecki
Postby Sir Ruff » Sun Oct 11, 2009 9:14 pm
radek tymecki wrote:ok so what should i do to hear for example 100% of vcf1 and 50% of vcf2?
keep the balance slider all the way towards "1" and turn VCF 2 volume knob halfway down in the VCA 1 panel... Or just move the slider closer to the "1" side when VCF 2 volume is turned all the way down in the VCA 1 panel... this will change the relative balance of the outputs of VCA 1 (which would only have VCF 1 being output), and VCA 2 (which would only have VCF 2 being output)
Sir Ruff
Postby radek tymecki » Mon Oct 12, 2009 3:50 pm
ok. but this shouldn't work like that;)
radek tymecki
Postby Sir Ruff » Mon Oct 12, 2009 5:10 pm
radek tymecki wrote:ok. but this shouldn't work like that;)
erm... not quite sure what you mean. did what I suggested work?
Sir Ruff
Postby radek tymecki » Mon Oct 12, 2009 5:38 pm
VCF1 and VCF2 are both placed on VCA 1 module
radek tymecki
Postby Sir Ruff » Mon Oct 12, 2009 5:59 pm
radek tymecki wrote:VCF1 and VCF2 are both placed on VCA 1 module
this allows you to have both the ring mod and clean vcf 2 signal at the same time... or to modulate the volume in two ways...
Sir Ruff
Users browsing this forum: No registered users and 11 guests
