I NEED KORG ES50 'LAMBDA' REPAIR HELP
Postby froonbazhooley » Fri Jun 04, 2010 9:54 pm
I am about to be in possession of a Korg Lambda, and according to the owner it has some "tones that shouldn't be there, and some octave problems with certain keys." Specifically, some of the keys play an octave higher than they should. I do not know what he is getting at with the mentioning of tones though...
No one at all that I have contacted has been able to suggest anything. Is there anyone who can point me in the right direction?
froonbazhooley
Gear: KORG MicroKorg
KORG Poly-800 Mk II
KORG ES50 'Lambda'
Casio VZ-10M
Alesis MMT-8 Sequencer
Roland TR-505
Kustom 88 Electric Piano
Band: MarshLights
Re: I NEED KORG ES50 'LAMBDA' REPAIR HELP
Postby rhino » Fri Jun 04, 2010 11:18 pm
Welcome to our world!
Likely one (or more) of the S10430 IC modules are dead.
Unless you've much experence with electronics, tools and soldering, I'd find a good tech.
- Confucius
rhino
Real name: bill
Gear: keepers:
Kurzweil K2500x
Ensoniq TS-12
Yamaha SY-99
Alesis QS-8
Roland JD-800
Roland JX-10
Akai AX-80
Korg DSS-1
Moog Mini
Fizmo
Postby froonbazhooley » Tue Jun 08, 2010 10:19 pm
Hm, I talked to an expert on ES50 repair, and that seems to be the case, I will have to probe it with the help of a better tech than myself to find out what is acting up.
Also, after cleaning it, taking the keys out, cleaning contacts etc. A few of the keys only play on the release of the key...? Does this mean I messed up one of the contacts one way or another, or is that another problem?
froonbazhooley
KORG Poly-800 Mk II
KORG ES50 'Lambda'
Casio VZ-10M
Roland TR-505
Band: MarshLights
Postby froonbazhooley » Thu Jun 10, 2010 2:37 am
Ah, I fixed mostly everything now...
It's quite easy to fix Lambdas I have discovered if you are handy with a probe... The Korg Deltas have the same chips and dividers, so they are not TOO rare of a find, though they are pricey...
froonbazhooley
KORG Poly-800 Mk II
KORG ES50 'Lambda'
Casio VZ-10M
Roland TR-505
Band: MarshLights
Users browsing this forum: Bing [Bot], Google Adsense [Bot] and 5 guests
