Moog Rogue slide pot replacement specs
Postby madphingers » Mon Nov 14, 2011 4:36 pm
Another Moog Rogue question! I got inside and cleaned out the nightmare goo. What a task! And I would like to replace the sliders and most have gone pretty stiff. Instead of spending $50-75 on one of the kits from Tech Transplant or the likes (no disrespect, just have a short budget) I would like to see if I can order from Mouser or Digikey, but don't know all of the specs.
I have the service manual so know that I need the following:
5 Linear 10k slide pots (OSC 1, OSC 2, NOISE, CUTOFF, and AMT)
2 1M audio (ATTACK, DECAY)
1 50K audio (EMPHASIS)
And I am pretty sure they need to be 1/4 W (5% tolerance). The manual states: "unless otherwised noted, all resistors are 1/4W +/-5%
Does anyone know the following:
Size/Dimensions (I suppose I'll just open it up again and measure...)
Voltage Rating (Mouser shows either 200 or 250)
Operating Temperature
Digikey also asks for
Series
Adjustment type
Thanks in advance
jake
madphingers
Re: Moog Rogue slide pot replacement specs
Postby Don T » Thu Nov 17, 2011 7:16 am
madphingers wrote:Another Moog Rogue question! I got inside and cleaned out the nightmare goo. What a task! And I would like to replace the sliders and most have gone pretty stiff. Instead of spending $50-75 on one of the kits from Tech Transplant or the likes (no disrespect, just have a short budget) I would like to see if I can order from Mouser or Digikey, but don't know all of the specs.
Series
Adjustment type
Thanks in advance
jake
I've been down this road before, only to find it a dead end. A 1M Audio slider is nearly impossible to find, in any configuration. Even if all new sliders could be found, they will likely cost more than the TT kit.
However, since you're on a budget do what I do: Take the slider apart, clean, re-lube and reassemble. Yes, it's tedious, but it isn't nearly as bad as removing the black goo from the outside. Plus, the price can't be beat!
Don Taylor
Master of no trades, practitioner of many.
(Basically, this means I know just enough about a lot of things to get myself in real trouble)
Don T
Real name: Don
Users browsing this forum: Baidu [Spider], damoik, Google Adsense [Bot] and 7 guests
