Kurzweil K2000 problem - effects insanity.
Postby jrombrasher » Sat Aug 11, 2012 3:40 am
I have a Kurzweil k2000 v3 w/orchestral that does the weirdest thing, I turn it on and after it boots, there is crazy screaming loud effects racket, I mean LOUD grinding digital effects noise pain! I know it is effects because if I turn them off it works fine dry, but I kind of like the effects and I want them to act right.
The strangest part of this, I have found that to fix it I can just hit the synth, Fonzie jukebox style, once or twice and it is fine for a good long while. I swear when I do this I can hear the effects altering, almost like there is an actual spring reverb in there. I have taken it apart, looked for loose or amiss connections etc. but to no avail. Also I am not really certain which board or part of what board contains the effects so I can look at it closer. It is driving me crazy, anyone ever have a problem similar to this? I'd really like to stop punching this thing...
jrombrasher
Re: Kurzweil K2000 problem - effects insanity.
Postby Virgule » Sat Aug 11, 2012 3:55 am
Have you reset the machine (Soft or Hard Reset)?
Virgule
Postby jrombrasher » Sat Aug 11, 2012 4:20 am
Yes, I've done that and the problem still returns, the noise doesn't happen always but maybe half the time.
jrombrasher
Postby rhino » Sat Aug 11, 2012 5:04 pm
FWIW, I have a K2500x that did the same type of thing: Any patch using reverb had a constant tone (about 1200 Hz), also controled by the effects level. Any patch with phazer had a ragged FM-like tone. The "base" FX chip is not available, so I ended up buying an audio board (used) on Ebay.
- Confucius
rhino
Real name: bill
Gear: keepers:
Kurzweil K2500x
Ensoniq TS-12
Yamaha SY-99
Alesis QS-8
Roland JD-800
Roland JX-10
Akai AX-80
Korg DSS-1
Moog Mini
Fizmo
Postby Steve Jones » Sun Aug 12, 2012 11:23 am
From memory the effects chip was a Dod chip, they were always a bit failure prone, perhaps you have a bad solder joint on the FX chip, if the board has flexed it may have cracked a surface mount solder joint which may need re-flowing.
Steve Jones
Real name: Steve
Postby jrombrasher » Sun Aug 12, 2012 10:13 pm
Thanks for the suggestions y'all, I will open it up and check the boards.
jrombrasher
Postby chrispoacher » Wed Feb 26, 2014 4:51 am
Hi, I have the same problem with my K2000R. To get around it I just use the 'dry' outputs 1-2 but there is still some very small buzzing noise left. I've replaced some of the JFET's on the output board and I have the diodes to fit also which may help a bit. I would really like the Effects to work though, is it possible to replace the chip or do I need to replace an entire board, and if so which board.. This is a superb piece of kit that would get used a whole lot more in my setup if it wasnt for this problem. Chris
chrispoacher
Postby scottrod » Sun Mar 02, 2014 7:39 pm
The effects section is right by the outputs.
I had a spare board I worked on for a few months but never could get the effects operational. Dry was fine. Finally gave up and sold it for parts.
I was not impressed with the board itself. I've never seen traces pop loose so easily. Cheap manufacture IMO.
scottrod
Real name: Scott
Gear: MKS-70 | D-50 | JD-800 | Jupiter-80 | WaveStation | SY99 | EX5 | FS1R | Montage 8 | Prophet-6 | JP-8000 | Integra-7 | JX-10 | JD-990 | TG-77 | D-550
Postby ron3113 » Sat May 30, 2015 1:30 pm
I have this exact same problem - the OPs description of the weird noises are spot on.
Did you ever manage to solve this? Was it the soldering issue suggested?
Cheers
Ras
ron3113
