need key bushings for ARP solus
Postby shaft9000 » Wed May 29, 2013 5:05 pm
hi all
i had no luck searching new bushings on Ebay for a solus - substituting Odyssey in the search didn't turn up anything, which was surprising.
does anyone know where i can source them??
shaft9000
Real name: Dave
Band: moneymoneymoney
Re: need key bushings for ARP solus
Postby perfectdefect » Wed May 29, 2013 6:39 pm
If they are indeed the same as Odyssey ::I don't know -seems like they should be:: you can get then from Syntaur. I've successfully bought stuff from them in the past.
http://www.syntaur.com/4169.html
perfectdefect
Real name: atu
Gear: MPC1000 Kingston MS20 Sigma PolySix JU60 JU106 RS09 TR66 200A Micro Opus 3 Stage 73
Band: infinite now
Postby analoglsd » Wed May 29, 2013 7:53 pm
You can also get bushings from Vintage Vibe:
https://www.vintagevibe.com/p-484-synth ... hings.aspx
They're cheaper than Syntaur, and for $1 more, they'll come lubricated,which is important.
I've always ordered mine from VV, and never had any problems.
If you use the wrong lubricant on bushings, it can lead to keys sticking.
analoglsd
Real name: Lance
Postby atkbg » Fri May 31, 2013 11:24 am
http://pw2.netcom.com/~arcsound/
This guy has been supplying them for a long time.
I purchased my last set from him.
synthfool recommended them to me.
atkbg
Postby Hiwatt » Fri May 31, 2013 6:49 pm
Give Bob at http://www.sounddoctorin.com a shout. I've gotten bushings for several Pratt Read keyboards from him. His prices are reasonable and he ships quickly.
Hiwatt
Postby schmidtc » Fri May 31, 2013 8:11 pm
+1 - I just bought a few hundred bushings from Bob, so his stock may be low. he's your cheapest option, and I think the quality of the molding is maybe a bit better than the others I've tried.
Also, although there's a few different types of P&R keyboards, all Pratt and Read keys use the same bushing type.
schmidtc
Postby shaft9000 » Fri May 31, 2013 8:25 pm
schmidtc wrote:Also, although there's a few different types of P&R keyboards, all Pratt and Read keys use the same bushing type.
if so then that's a relief
...and thanks for spoiling me for choice, folks
it's always good to have more part sources :)
shaft9000
Real name: Dave
Postby Steve Jones » Mon Jun 03, 2013 10:54 am
I have tried several types and the only ones that really lasted well are those from Archive sound.
The other option which I used on my PPG is a completely different method of repairing a Pratt Read action but the result is far, far better than any normal rubber bushings but more time consuming to install. The result though is an action that feels an order of magnitude better than even the best Pratt-read action with new conventional bushings. Available here:
http://www.virtual-music.at/webseiten_e ... m#keyboard
Steve Jones
Real name: Steve
Postby shaft9000 » Wed Jun 05, 2013 3:17 am
a buddy mailed me some extras he had and i got them all on today in about an hour's work...the Solus is really easy to fix... like a VW bug. :)
i eliminated all crackling with some FaderLube5
a couple light pre-coats (well cured) of armor-all on the bushings has 'er playing sweeter than ever! :keys1:
thanks again for all the recos. mates :)
shaft9000
Real name: Dave
Users browsing this forum: Bing [Bot], Google Adsense [Bot] and 9 guests
