thank you!
muhammed
Band: madtheory
muhammed
muhammed
Band: madtheory
recording db:-3-db.-5 db
muhammed
thank you!
muhammed
Band: madtheory
thank you again
muhammed
Solderman
Real name: Zane W
Band: madtheory
Return to Sound Production
Users browsing this forum: >DMF< and 4 guests
