iPad 4/Lightning...audio over USB?
Postby meatballfulton » Mon Jun 24, 2013 7:20 pm
I own a class compliant M-Audio controller that supports both MIDI and audio (44.1/16 stereo in/out) over USB.
Will the Apple Lightning camera connector pass audio over USB as well as MIDI?
Re: iPad 4/Lightning...audio over USB?
Postby sequentialsoftshock » Wed Jun 26, 2013 12:18 pm
I believe it depends on the app as well as the power consumption. You can't instantly plug in a multi channel interface to the iPad, even if you have the units power adapter in. In my experience it will still show the power consumption is too high.
bonne chance
sequentialsoftshock
Real name: Zayne
Band: Echo & Liora
Postby clubbedtodeath » Fri Jul 05, 2013 6:49 pm
Mr Fulton,
There is a way around this. If you attach your iPad to a powered USB hub, you can connect the M-Audio controller to that. The iPad should still see the controller, but the hub will be powering it.
I did this with an Oxygen8 v2 - which is MIDI only; worked with Nanostudio a treat. Let us know how you get on,
Cheers
clubbedtodeath
Postby meatballfulton » Fri Jul 05, 2013 11:50 pm
I don't need power over USB, just audio.
Guess this means a trip to the Apple Store :help:
Postby clubbedtodeath » Sat Jul 06, 2013 11:08 am
meatballfulton wrote:I don't need power over USB, just audio.
Ah no, the power's not for the iPad -- it's just so the controller can draw power from the hub, rather than trying to draw it from the iPad.
clubbedtodeath
Postby Carey M » Sat Jul 06, 2013 1:09 pm
Some USB audio and MIDI interfaces work just fine without a powered hub, but yeah, many do not. I use the Lightning-USB Camera Connection kit with a M-Audio Keystation 61ES and I don't need a hub, but that's MIDI only.
At least some interfaces can provide audio as well as MIDI simultaneously to the iPad, Novation Xios can do this (with a hub) as well as Apogee's latest Duet and Quartet, probably others as well.
Carey M
Gear: Akai Miniak, Fender Chroma Polaris, Moog Sub Phatty, Roland SH-101, Roland Jupiter-4, Sequential Circuits Prophet-600, Komplete 8, Reaper, iPad, beer
Band: Nightsatan
Postby meatballfulton » Sat Jul 06, 2013 3:09 pm
clubbedtodeath wrote:the power's not for the iPad -- it's just so the controller can draw power from the hub
My controller has it's own PS, using a powered hub just adds an extra box.
Postby meatballfulton » Sat Jul 06, 2013 4:01 pm
Just checked with Apple via online chat and was told no, it won't work.
Postby clubbedtodeath » Sat Jul 06, 2013 10:31 pm
meatballfulton wrote:My controller has it's own PS, using a powered hub just adds an extra box.
So does mine, but for some reason the Oxygen8 still wants to try and draw power from USB - even if I've got an adapter plugged into it; hence the USB hub. Anyway, sorry to hear it didn't work out in the end.
clubbedtodeath
Return to Sound Production
