Omni-2
Omni-2
Postby smsayre65 » Mon Aug 05, 2013 2:36 am
Hi
I have an ARP Omni-2 and it has all black buttons. I've searched all over, including here, and can't find anything about it. Every pic I've seen they have the orange and cream colored buttons. Anyone ever heard of an Omni-2 with all black buttons??
1974 ARP Solina MKI String Ensemble
1978 ARP OMNI-2
1979 ARP Quartet
1982 SCI Prophet 600
1976 MicroMoog
1975 Crumar MultiMan-S
1995 Hammond XB-2 Drawbar Organ and Leslie
1966 Farfisa Compact Combo Organ
1989 Rhodes MK80
2005 Kurzweil SP88X Piano
smsayre65
Real name: Steve
Gear: 74 ARP Solina MKI
78 ARP OMNI-2
79 ARP Quartet
82 Prophet 600
76 MicroMoog
75 Crumar OTR
95 Hammond XB-2
66 Farfisa Organ
89 Rhodes
05 Kurzweil SP88X
Band: Many...
Re: Omni-2
Postby LWG » Mon Aug 05, 2013 6:30 am
smsayre65 wrote:Hi
Hello!
Yes, iirc, they're the last production version. They have black push switches, but where they differ
from the Omni-2 version that appeared before them is they have a removable plate(s?) on the underside of the
casing to allow access to the keyboard assembly from underneath.
The units prior to them forced you to remove the keyboard assembly to access the underside mechanics.
The vast majority of the Omni-2's were of the previous version and had the cream/orange push switches.
Regards,
-L
LWG
Re: Omni-2
Postby LWG » Mon Aug 05, 2013 9:46 am
smsayre65,
If you don't mind my asking, whats the serial number on your unit? You've piqued my curiosity, as the Omni-2
in ARP's product catalog from the late 70's has the black button version.
I may be off about the order in which the two versions appear, but I do remember that the black button
versions are way fewer than the orange/cream ones. They are also the only Omni-2's I have ever seen with the underside keybed access hatch (ala Odyssey III). Additionally they have an led power indicator and ARP badge
just to the right of the keyboard, whereas the orange/cream versions is usually blank in this location.
Regards,
-L
LWG
Re: Omni-2
Postby ppg_wavecomputer » Mon Aug 05, 2013 8:28 pm
It might have been repaired at some point, with the right type of switchboard not available. I´ve seen several Pro-DGXs with either orange switch caps where these should have been black, or I´ve seen later ones which should have orange ones but had black ones instead.
Or maybe it´s a Frankensynth assembled from various other Omnis?
Stephen
"Like the light from distant stars, Stephen Parsick's music has existed for some time, but is only now reaching us on Earth." -- Chuck van Zyl / Star´s End
ppg_wavecomputer
Band: ['ramp]
Re: Omni-2
Postby Micke » Mon Aug 05, 2013 8:29 pm
I on the contrary believe the Omni-2 with all-black buttons is the earliest version because that's the one pictured in the service manual
(copyrighted july '78). The instruments pictured in 1979-80 adverts are the orange/cream version though, this one for example:
http://www.scottfromcanada.com/synthads ... 201980.jpg
and this: http://i.ebayimg.com/t/1979-ARP-Omni-2- ... ~60_57.JPG
Also, I'm pretty sure the ARP product catalog LWG's referring to dates from 1978 considering that the Quadra isn't featured** (at least
not in the one I have), and the Omni 2 pictured in there is the all-black button version. I found a serial number for this version and it's
in the low 200's, suggesting it is in fact an early version.
The cream/orange version is definitively the most common one.
** the Quadra didn't hit the streets until the spring of 1979 or thereabouts.
EDIT: here you can download a PDF version of the ARP product catalog (I'm sure it's from 1978 though, not 1977)
http://www.preservationsound.com/wp-con ... atalog.pdf
Micke
Re: Omni-2
Postby CZ Rider » Tue Aug 06, 2013 4:36 pm
The most noticable feature on those early black/orange Arps was the wood sides and a green metal/ceramic logo on them. Never noticed the Omni-2 had those all black caps too.(Nice find Micke!) Are there wood sides on that black capped Omni-2?
Seems like the very early ones were manufactured with thin wood sides, and later replaced with those common and strange leather sides. I have seen most of the early black/orange wood sidded models, and I have both an early Avatar and Axxe II. Not sure when they stopped or how long they made these, but the wood looks nice on those early black/orange generation Arps.
The green/metal Logo came in different sizes. The Avatar one is much larger.
Axxe logo:
Avatar logo:
And the wood side:
I would guess if the Omni-2 had original black caps, it probably had the green/metal logo and wood sides too. Making that a nice Omni-2!
CZ Rider
Re: Omni-2
Postby Micke » Tue Aug 06, 2013 6:48 pm
CZ, I have gone through some pics I have of black-capped Omni 2's and it does look like at least
some have thin wood-sides and the green/metal logo.
The one pictured here for example:
http://www.flickriver.com/photos/matrix ... 595505373/
Note that it also has a slightly different looking back panel.
Here's a photo of another black-capped unit which appears to have wood sides (red slider-tops not original of course):
http://farm3.staticflickr.com/2574/3988 ... 4ec6_o.jpg
The Omni 2 pictured in the 1978 catalog (see PDF posted above) appears to have wood sides too but it's difficult to say for sure.
And here we have an odd one (it has the cream/orange buttons as well as the green/metal logo!):
http://2.bp.blogspot.com/-f2LTtuXo8Eo/U ... ~60_57.JPG
Micke
Re: Omni-2
Postby smsayre65 » Wed Aug 07, 2013 7:16 pm
Hi everyone
Sorry for the delay, I had an injury....Thanks for the replies, SUPER helpful !!! The serial number for the Omni-2 is 24730209. I attached some pics of it as well. Image Image Image Image Image
1978 ARP OMNI-2
1979 ARP Quartet
1976 MicroMoog
1989 Rhodes MK80
smsayre65
Real name: Steve
78 ARP OMNI-2
79 ARP Quartet
82 Prophet 600
76 MicroMoog
75 Crumar OTR
95 Hammond XB-2
66 Farfisa Organ
89 Rhodes
05 Kurzweil SP88X
Band: Many...
Re: Omni-2
Postby LWG » Sun Aug 11, 2013 9:10 am
smsayre65,
Do you have the removable keybed access plate(s) on the underside of the cabinet?
Regards
-L
LWG
Re: Omni-2
Postby smsayre65 » Mon Aug 19, 2013 4:09 am
No, there aren't any key bed and/or mechanics access plate(s). I'm thinking this is an early one due to the information you all provided, which is spot on: wood sides, green badge, no access plate(s), black buttons, etc. I looked at the product catalog from '78 you all were referencing and it sure does look like that one pictured with wood sides, black buttons and ARP badge. I think I'll go with an early one unless anyone has some other clue?
1978 ARP OMNI-2
1979 ARP Quartet
1976 MicroMoog
1989 Rhodes MK80
smsayre65
Real name: Steve
78 ARP OMNI-2
79 ARP Quartet
82 Prophet 600
76 MicroMoog
75 Crumar OTR
95 Hammond XB-2
66 Farfisa Organ
89 Rhodes
05 Kurzweil SP88X
Band: Many...
Re: Omni-2
Postby Micke » Mon Aug 19, 2013 1:43 pm
Hmm...this one http://www.flickriver.com/photos/matrix ... 595505373/ does have the removable plate on the
underside of the cabinet and its serial number is very close to yours. The plot thickens!
Micke
Re: Omni-2
Postby smsayre65 » Mon Aug 19, 2013 4:21 pm
@ Micke
Yes, the plot certainly does thicken.....That example from Matrix Synth looks exactly like mine. The serial number is 2473202 and mine is 2473209. Literally 7 numbers difference. I couldn't find the year of manufacture listed. Not sure if the person knows? I know I'm having a bit of difficulty.... That's awesome that you found that and much appreciated. Those are good pics and show a lot of detail. Mine isn't scratched up hardly at all and is in really good condition. The guy I bought it from bought it new and had it in storage for many years. He said he thought he bought it in 1978 or 1979.
Steve
1978 ARP OMNI-2
1979 ARP Quartet
1976 MicroMoog
1989 Rhodes MK80
smsayre65
Real name: Steve
78 ARP OMNI-2
79 ARP Quartet
82 Prophet 600
76 MicroMoog
75 Crumar OTR
95 Hammond XB-2
66 Farfisa Organ
89 Rhodes
05 Kurzweil SP88X
Band: Many...
Users browsing this forum: salwa and 13 guests
