Akai MPX8 Sample Player
Postby meatballfulton » Tue Jul 09, 2013 7:54 pm
The manual is here but the units are still not shipping, maybe summer NAMM will have more news.
Re: Akai MPX8 Sample Player
Postby meatballfulton » Tue Jul 09, 2013 8:11 pm
Quickies from the manual:
-- Includes a USB power supply...means one less jack on the unit.
-- Stereo I/O with two 1/4" jacks, L/Mono and R; 1/8" headphone out
-- samples must be mono though they can be panned and retuned
-- supports WAV at 48, 44.1, 32, 22.05 or 11.025K at 16 bits
-- Max memory is only 30MB across all 8 pads (no streaming, ouch) :oops:
-- pads can be used for MIDI control with polyphonic aftertouch
-- no info on the built-in samples
-- onboard reverb, depth is assigned per pad
-- one shot, hold and loop triggering per pad
-- a kit is a set of 8 pads, can be internal or external (on SD card) though no mention of how many kits you can have
-- max number of files (both individual samples as well as saved kits?) on SD card is 512 regardless of size
-- free downloadable sample editor
-- MIDI IN and OUT using supplied 1/8" to 5-pin DIN cables
Postby Hugo76 » Wed Jul 10, 2013 12:44 am
If it was possible to sample with the thing, I might be interested
Hugo76
Postby tim gueguen » Wed Jul 10, 2013 5:11 am
I looked at the MIDI spec a bit ago, and it won't accept pitch bend data.
tim gueguen
Postby cgren72 » Wed Jul 10, 2013 6:09 pm
I was wanting to buy one but the more I look at it, the more unappealing it becomes. The 30MB limit is kind of a turn off. Streaming longer samples was one of its highlights in my mind before I saw that. For $99 new though, it isn't too bad
cgren72
Postby supermel74 » Fri Aug 09, 2013 4:19 pm
They're now available everywhere for $99. Not bad but I'll be waiting until the Ebay music retailers are selling B-stocks for $69 or so
supermel74
Postby ilovemusic » Sat Aug 10, 2013 9:48 pm
still no editor software
They forgot that or something?
ilovemusic
Postby cgren72 » Sat Aug 10, 2013 10:11 pm
supermel74 wrote:They're now available everywhere for $99. Not bad but I'll be waiting until the Ebay music retailers are selling B-stocks for $69 or so
Are they available now? All the sites I looked on said it was still on pre-order.
I want it for its pads as much as I want it for its sampling. I'm getting so tired of piano rolls..
cgren72
Postby cgren72 » Sat Aug 10, 2013 10:12 pm
ilovemusic wrote:still no editor software
Editor software for what?
cgren72
Postby Hugo76 » Sun Aug 11, 2013 1:40 am
cgren72 wrote:Editor software for what?
The manual states that the editor is used for transferring damples to the SD card, although it can be done without it.
cgren72 wrote:I want it for its pads as much as I want it for its sampling.
Be aware that the unit isn't capable of sampling, only sample playback.
Hugo76
Postby cgren72 » Sun Aug 11, 2013 6:19 am
I knew it couldn't sample, but I want to use the pads to control my main sampler. Just a mix-up of words I suppose
cgren72
Postby ryryoftokyo » Tue Sep 24, 2013 6:52 pm
I just saw this last night, and I'm into the idea, but is there anything a bit more full featured for a similar price (between $100 and $200)? Or should I just grab this? Sampler n00b.
ryryoftokyo
Real name: Ryan
Band: Tarot Sync
Postby tim gueguen » Wed Sep 25, 2013 1:03 am
Nothing available new as far as hardware goes. There are all sorts of used things of varying capabilities you could find in that range used. But a caution with older units is that they use older sorts of data storage materials like Smartmedia cards that may be a bit of a problem to find.
tim gueguen
Postby robotunes » Wed Sep 25, 2013 2:49 am
>>is there anything a bit more full featured for a similar price (between $100 and $200)? <<
if you have an iphone 4 or 5 (or a 5th gen ipod), the beatmaker2 app goes for $20. that plus an iConnectMIDI2+ ($120 with adapter) and a cheapo midi controller can work wonders (being a noob, you'll have a lot of questions tho)
robotunes
Postby Hugo76 » Sat Oct 05, 2013 1:03 am
Just came across Nick Batt's (Sonic Lab) review of the Akai, and he mention's that the firm ware is upgraded to allow for stereo samples:
http://m.youtube.com/watch?v=C8IIEsjloW ... 8IIEsjloW8
Hugo76
Return to Samplers
