Crumar Bit 99 Fuse Holder Needed
Postby osgoodeian » Thu Jan 09, 2014 1:06 am
Hello,
The fuse holder on my Crumar Bit 99 is dead and I have no idea where it is or what kind it was.
Does anybody have one of these for sale or have a pic I can see to try to get a new one?
Thanks
osgoodeian
Re: Crumar Bit 99 Fuse Holder Needed
Postby rhino » Thu Jan 09, 2014 1:38 am
Welcome to the board!
Give us a little more information to go with your problem: Why do you think it's the fuse holder?
Looks (from a schematic) that there are 4 fuses. Most likely they are in holders mounted on the power supply board, although the one in the main A.C. line may be by itself near where the line cord enters the case.
- Confucius
rhino
Real name: bill
Gear: keepers:
Kurzweil K2500x
Ensoniq TS-12
Yamaha SY-99
Alesis QS-8
Roland JD-800
Roland JX-10
Akai AX-80
Korg DSS-1
Moog Mini
Fizmo
Postby osgoodeian » Thu Jan 09, 2014 2:04 am
Thank you! It's the 500 Ma fuse by the AC input.
I've got the fuse, the spring and the inner metal clip but no cap to screw in - you know
the little doodad you have to thread in?
osgoodeian
Postby rhino » Thu Jan 09, 2014 3:30 am
OK. What country are you in? Farnell, Futurelec if you're in Europe, Mouser if you're in the US.
Does this look anything like it?
http://www.jameco.com/webapp/wcs/stores ... _102832_-1
- Confucius
rhino
Real name: bill
Gear: keepers:
Kurzweil K2500x
Ensoniq TS-12
Yamaha SY-99
Alesis QS-8
Roland JD-800
Roland JX-10
Akai AX-80
Korg DSS-1
Moog Mini
Fizmo
Postby osgoodeian » Thu Jan 09, 2014 5:06 am
I'm not sure. The plastic cap broke off the end and I can't locate it.
I was hoping someone with a Crumar Bit 99 synth could post a pic of theirs.
osgoodeian
Postby osgoodeian » Thu Jan 09, 2014 5:24 am
I'm in Canada. I'm hoping to be able to just replace the fuse cap end.
osgoodeian
Postby madtheory » Thu Jan 09, 2014 1:55 pm
This is a common problem with these. It's a standard size panel mount fuse holder. The cap is unobtanium so you will have to replace the whole thing, probably less than a dollar to buy, easy to do if you can solder.
Band: madtheory
Postby rhino » Thu Jan 09, 2014 4:46 pm
Here's a used Crumar part from a diferent synth, but may fit...if you're into original parts...
http://www.syntaur.com/4014.html
- Confucius
rhino
Real name: bill
Gear: keepers:
Kurzweil K2500x
Ensoniq TS-12
Yamaha SY-99
Alesis QS-8
Roland JD-800
Roland JX-10
Akai AX-80
Korg DSS-1
Moog Mini
Fizmo
Postby osgoodeian » Thu Jan 09, 2014 9:04 pm
Great. Thanks.
osgoodeian
Postby nsputnik » Mon Jan 13, 2014 1:50 am
I need a Bit One fuse and holder. Does anyone know the specifications on the fuse an what size the fuse holder is?
nsputnik
Gear: jp8 ju106 ju60 ju2 sh101 odyssey indigo nordlead an1x emax chromapolaris prophecy matrix1000 xbase09 s3000xl tx81z sidstation midines esq1 shermanfb2
Users browsing this forum: Google Adsense [Bot] and 10 guests
