MOOG SUB37 vs KARP Odyssey
Postby zoomtheline » Tue Feb 18, 2014 5:38 pm
Now, i'm not really a fan of these types of threads as usually you can just find out for your self or just dive in and try them to make your own mind up, it's pretty subjective anyway right?
I have not touched these before, obviously. Not even a Subphatty or the original Odyssey but there is not denying that there are obvious things in common with these two.
I have pretty sold myself on the SUB37 but this crazy odyssey news came straight out of left field.
Maybe it's worth discussing the pro's and cons of each? as many will be in this same conundrum.
zoomtheline
No Longer Registered
Re: MOOG SUB37 vs KARP Odyssey
Postby moodorf » Tue Feb 18, 2014 6:49 pm
KARP Odyssey?
Something sounds fishy about that.....
all kidding aside, I'd go with the moog simply due to it's paraphonic mode, and the knobbiness.
moodorf
Gear: Little Phatty (needs repair)
Blofeld
DSI Prophet 08
Ensoniq SQ80
Pittsburgh Modular System 10
Renoise
FL
Postby zoomtheline » Tue Feb 18, 2014 6:54 pm
I nearly put Karpov codyssey but thought too silly ;)
Well, they are both 2 osc with duo phonic mode in pretty much the same way so there's the obvious comparison.
zoomtheline
Postby Sir Nose » Tue Feb 18, 2014 7:44 pm
I don't think they'll be in the same ballpark pricewise. The Sub 37 will be double to triple the cost of the KARP.
Funkadelic wrote:nothing is good unless you play with it
all that is good is nasty
Sir Nose
Real name: Bob
Postby meatballfulton » Tue Feb 18, 2014 7:56 pm
-- Moog will have full MIDI implementation...knobs sending CCs, patch memories,velocity, aftertouch, etc. KARP most likely will not.
-- Moog has bend and mod wheels, KARP will have "PPC" (pressure sensitive) bender only.
-- Moog has limited CV inputs, if KARP is true to the original it will have CV/gate/trigger ins and outs.
-- Moog will sound, eh, Moogy. ARPs always had a thinner, more cutting sound.
-- Moog will be made in USA, KARP most likely in China.
-- Moog will be about $1500, KARP...who knows.
Postby zoomtheline » Tue Feb 18, 2014 7:59 pm
I think you're probably right, well, I hope you're right because then maybe I could afford to save for the arp after with that timescale.
Of course the moog has more modulation, the arp, sequencer and various filter and envelope parameters which make it more flexible but the arp has some cool quirky features that you don't really see often. Is that sound and heritage worthy of squaring up to the fully featured moog?
(Karpov? Damn iPad)
zoomtheline
Postby zoomtheline » Tue Feb 18, 2014 8:11 pm
Also, how the h**l did I post in the wrong category? Mods feel free to slap my wrist and move to shootouts. Sorry.
zoomtheline
Postby shaft9000 » Tue Feb 18, 2014 10:03 pm
100% SPECULATION (from a phattyTE owner, ex-Voyager owner, and moderate ARP freek)
the moog is growly and schmoove, a bit thicker and rounder in sound, and will feel more ...expensive; well-behaved.
the Koddy will be brash and blaster-y (if they do it right). it will probably be a lot lighter in build and parts.
a bit toy-ish in feel, yet more fierce and sooo classic sounding, ironically.
a subPhatty compares a lot better price & complexity-wise.
shaft9000
Real name: Dave
Band: moneymoneymoney
Postby Sir Nose » Tue Feb 18, 2014 11:38 pm
meatballfulton wrote:-- Moog will have full MIDI implementation...knobs sending CCs, patch memories,velocity, aftertouch, etc. KARP most likely will not.
Pretty much nailed it. Except most of the Moog will be made it China too. At least the cases will be stuffed in the USA for the tribute.
Sir Nose
Real name: Bob
Postby meatballfulton » Wed Feb 19, 2014 12:54 am
Really, Moog is having most of the mfg done in China these days? Sigh... :oops:
Postby Stab Frenzy » Wed Feb 19, 2014 1:37 am
What, you don't think people in China can make things as well as people in America?
The Little Phattys were all made in China and then assembled in the USA, nobody ever complained about it before.
Postby Kenneth » Wed Feb 19, 2014 6:39 am
Stab Frenzy wrote:What, you don't think people in China can make things as well as people in America?
Where did you get that info? I have been trying to figure out for myself whether that's true or not.
Kenneth
Real name: Kenneth
Gear: Analog Four, OP-1, AN1x, PSS-470, PSS-480, DR-770, Vermona Retroverb Lancet, Tascam Porta One
Band: KGB
Postby Stab Frenzy » Wed Feb 19, 2014 7:39 am
From Moog themselves then the LP was first announced. The boards are made and populated in China and then shipped to the US where finally assembly is done (ie they put the boards in the casings, attach the other bits and pieces, do final testing and calibration). So they can say 'made in the USA' on them as that's where the final process occurred but the actual circuitry, all sound generating parts are made in China.
Postby Steve Jones » Wed Feb 19, 2014 10:04 am
I don't need a new Odyssey and I rarely buy modern synths but the two things that I am putting money aside for and am excited about are the the new Moog (I love duophonic lead synths) and the Roland TR-8 ( I have inside info and it will be amazing). The thing that I really love about all this new gear is that HARDWARE IS BACK!
Steve Jones
Real name: Steve
Postby pflosi » Wed Feb 19, 2014 2:42 pm
Cool, MOOG vs ARP threads - are we back to the 70ies yet? :mrgreen:
