ARP omni release
ARP omni release
Postby sam » Thu Feb 20, 2014 9:12 pm
Hello everyone ...I have been away for a while moving house...
I am trying to fix a problem affecting the release. I have checked just about everything on the string board so i am now thinking the problem lies on the voice boards.
All the caps are replaced so thats not the issue here....
Has anyone here experienced release or maybe sustain problems on theirs..?
ms20/50.Andromeda. OBX.
sam
Re: ARP omni release
Postby WhinyLittleRunt » Fri Feb 21, 2014 3:51 am
Did you replace the caps on the control/slider boards too? I have yet to do mine and have the same issue and was told I missed some...
roland jupiter 6 | oberheim ob-8 | moog prodigy | moog opus 3 | yamaha s90es | yamaha cp30 | arp omni-2 | arp odyssey mkIII | linndrum | simmons sdsv | acetone fr-3 | 82 rhodes mark II stage | wurlitzer 200a | hammond m100
WhinyLittleRunt
Postby synthparts » Fri Feb 21, 2014 6:04 am
The tantalum caps are all over the place. Close to 100 of them in an Omni. Even on the little VCF module board.
synthparts
Postby sam » Sat Feb 22, 2014 7:55 am
Thanks.....It can't be a cap fault or chip on the string board because i changed the lot...Except for a 4016 that just changes the lights...?
I don't get O/-15 on TP 1 though..?
This is really getting tricky....Hmm anyone..:)
sam
Postby Steve Jones » Sat Feb 22, 2014 8:53 am
Have you tested the release slider?
Steve Jones
Real name: Steve
Postby sam » Sat Feb 22, 2014 12:46 pm
Yup...The sliders fine and cleaned /lubed ect....
Could be something to do with the sustain/triggering ect....?
sam
Postby sam » Sun Feb 23, 2014 9:36 am
I feel it's possible that a logic chip has failed down the line....My question is which chip affect the release time..?
I will also do the psu mod...
sam
Postby V301H » Mon Feb 24, 2014 12:19 am
I had a new Omni 2 in the late 70's and the Release malfunctioned, staying long, shortly after I bought it. In this case it was a bad cap.
Prophet 5 rev.2, Pro-One, Juno 60, Jupiter 6, Matrix 12, OB8, MS20, Poly 800, CS70M, DX-7, CP35, Casio PX-5S, Hammond C3/M102, Vox Continental/Super Continental, Gibson G101, Farfisa Compact, RMI 300A, Pianet N, Combo Pianet, S770, S760, S50
V301H
Band: The Characters
Postby sam » Mon Feb 24, 2014 9:04 pm
Still searching but nothing yet is making sense....Could some with an omni count how long the release times are..?
On mine short...4s long 7s .....Is this normal..?
sam
Postby sam » Sat Mar 01, 2014 9:24 pm
After some searching a couple of resistors were broken (look out for this on omni boards as the end goes straight into the pcb) and a paper cap was broken...Works now but a very annoying fix.
sam
Postby yorgatron » Mon Mar 03, 2014 1:09 am
sam wrote:After some searching a couple of resistors were broken (look out for this on omni boards as the end goes straight into the pcb) and a paper cap was broken...Works now but a very annoying fix.
I just got an Omni and it has the same problem. mind taking a pic of the part(s) you fixed, just so I know where to look?
yorgatron
Gear: ARP Axxe
ARP Omni I
Korg Poly-61
Korg MS-10
Korg Mini-Korg 700
Elka X-55
RMI 300A
Wurlitzer 206A
Hohner Clavinet/Pianet Duo
Casio XW-P1
Band: Asha-Med
Postby sam » Mon Mar 03, 2014 10:27 am
It's really a situation where you have to desolder the green or white caps and see if the legs are ok or connecting properly..Also the same with the resistors.
I would however change the tantalums (blue ) .....There is no easy option with this as you have to desolder the board and check what you can....This seems to be a common problem with this board.
sam
Postby sam » Sat Mar 08, 2014 8:15 am
Also check or replace the 2 22mf tants and the 100 ohm resistor under the release slider..
sam
Postby error_trials » Fri Mar 28, 2014 8:29 am
Helpful post. I'm working on one of these, all the notes behave as they should as I adjust the attack/release sliders *except* for the lowest 6 which are stuck on the long release time. I suspect it must be the green and white resistor block for that group - this post supports that idea.
maybe a dumb question but can you get replacements for these old block resistors?
error_trials
Postby tomorrowstops » Sat Mar 29, 2014 9:30 pm
Apparently everyone's working on Omni's this year, huh? :D
tomorrowstops
Users browsing this forum: Bing [Bot], SerialSinger and 7 guests
