Akai MPX8 "Sample Player" Teardown
Postby DX21 » Wed Feb 05, 2014 12:11 pm
First off, this ain't no review, this is an electronic biopsy.
Ok. so I picked up this little bugger for about $100 because it seemed like a neato drum machine.
Curiously, knowing Akai and their lazy however effective design ideals of "Lets grab a bunch of off the shelf chips that do at least one of the things we want it to do and build some good gear around it" I decided to pop this bugger open.
I didn't expect much, after all it was 8 pads, 4 buttons and a Rotary knob.
However, the chips inside gave me a bit of a bit of surprise.
The main chip is a Medeli A2 Processor chippy which looks like this:
Possible Datasheet, seems to be at least close: http://www.icmedeli.com/download/M2000SPEC.pdf
The other notable chips are what appears to be a 1mb flash chip for the A2 Processor to boot off of Marked 1.0.0 which oddly in the Factory reset mode the "SD" is listed at 1.0.0 even after I installed the factory update, Note the Midi Error is because I had nothing plugged in at the time.
The Nice white text on blue reminds me of my old Commodore 64 :3 (wish I never sold the damn thing when I was a stupid teenager, I could be playing turrican right now :D)
The Large one marked V1.1.1 appears to be a 64MB Flash Chip
The EtronTech Chip is 16MB Ram and its datasheet is here: http://www.etron.com/manager/uploads/EM ... S_v1.4.pdf
The first line from the 1.0.01 firmware update appears as so: Medeli Electronics Co., Ltd.....AKAI MPX8.......V1.1.01.........20130609........SEL+....VAL+....................Data Number.é...A2_ISP.BIN......................A2..........A2..1MB.ini
Right now I'm poking around in the device's boot firmware, there might be a possibility to expand its Midi Implementation, install more ram for samples, Use MPEG Encoded samples (mp2, mp3), decrease load times, turn into a USB sound card, Maybe turn it into a simon says game, make it do the funky chicken, etc.
Interesting Secrets:
Select - and Volume- at power on brings you to the factory reset then the test mode.
Select+ and Volume + at power brings up the SD Firmware update mode.
Hope this is at least even remotely interesting to you.
-Dx21
~Chicks Dig My Solid Bass~
~Time Trax~
DX21: Needs new YM2151, Pitch Knob
DX21
Real name: Fender
Gear: Yamaha DX21
Kawai K3
Band: AHHHH!?!!?
Re: Akai MPX8 "Sample Player" Teardown
Postby Hugo76 » Wed Feb 05, 2014 6:28 pm
This is very interesting. Will you go ahead and modify the code? And do you think it'd be possible to add more features?
Hugo76
Postby Ugly Goblin Boy » Thu Feb 06, 2014 3:45 am
Wow, great break down! If you could figure out how to change the MIDI channel, that would be amazing. Having it stuck on 10 is a drag...
Ugly Goblin Boy
Postby somebedroomdj » Thu Feb 06, 2014 4:49 pm
Very cool thread! I don't know much at all when it comes to bending and stuff like that but how likely do you think it would be that an overdrive knob or switch could be added? I use mine strictly as a drum module and that would just be amazing.
In any case, looking forward to anything you find here. :D
Finally pared down to 3 machines and no GAS for months!
Tempest | Spectralis | MV-8800
I have a 64 patch Tempest soundset for 10 bucks, Here (16 bass drums, 48 synth patches)
somebedroomdj
Postby moremagic » Fri Feb 07, 2014 8:22 am
Ugly Goblin Boy wrote:Wow, great break down! If you could figure out how to change the MIDI channel, that would be amazing. Having it stuck on 10 is a drag...
but channel 10 is the cool channel!
moremagic
Real name: A.M.
Postby DX21 » Sun Feb 09, 2014 1:01 pm
somebedroomdj wrote:Very cool thread! I don't know much at all when it comes to bending and stuff like that but how likely do you think it would be that an overdrive knob or switch could be added? I use mine strictly as a drum module and that would just be amazing.
Underclocking or undervolting throws off the whole system, I've run it on a battery pack with deceased batteries and it seems to simply not tolerate low voltages as this is essentially the brain of a Midi Drum kit like a Yamaha DTX shoved in a little box.
I'm still sniffing the GPIO and such, maybe I can get it into bootloader mode or some crazy stuff
~Time Trax~
DX21
Real name: Fender
Gear: Yamaha DX21
Kawai K3
Band: AHHHH!?!!?
Postby DX21 » Sun Feb 09, 2014 1:25 pm
Update: I found a nifty Pad calibration menu if you hold select + and volume -,
My Velocities seem to go between 5 and 125.
It made the pads a bit more sensitive! :D
~Time Trax~
DX21
Real name: Fender
Gear: Yamaha DX21
Kawai K3
Band: AHHHH!?!!?
Postby DX21 » Sun Feb 09, 2014 2:02 pm
With a little messing with Audacity you can squeeze a whole average dance track into 8bit PCM @ 22khz :D
Its a fun way to use one of the pads, as you can play along with a track :D
8-bit PCM:
https://www.mediafire.com/?ab482j9j1ljfeal
It takes damn forever to load but the cool thing is it will keep playing even if you eject the memory card which is interesting...
~Time Trax~
DX21
Real name: Fender
Gear: Yamaha DX21
Kawai K3
Band: AHHHH!?!!?
Postby ABigPancake » Mon Feb 10, 2014 12:25 am
Hi,
It's really cool that you opened up the MPX8 :shock:. I was thinking of buying one but the main thing that put me off is that there is no battery power and people said the jog/data wheel is not great.
Based on your pictures I guess there could be room for an internal lipo battery and charging circuit 8-)
Did you get a look a the jog wheel? I wonder if it can be changed/fixed up better 8-)
Thanks so much for your post...
Adam :D
ABigPancake
Postby DX21 » Tue Feb 11, 2014 7:18 am
ABigPancake wrote:Hi,
Adam :D
There is enough room for a few flat pack lipo batteries inside, However it would be easier to pick up a nifty USB Battery pack though if you aren't adept with a soldering iron.
The jog wheel itself can be fixed up by putting a circle of baking paper or tracing paper (note not Wax paper) under the jog wheel's knob to keep it from grinding the plastic under the knob and making it hard to cycle fast.
:D
~Time Trax~
DX21
Real name: Fender
Gear: Yamaha DX21
Kawai K3
Band: AHHHH!?!!?
Postby ABigPancake » Tue Feb 11, 2014 3:04 pm
Adam :D
:D
Hi,
Thanks for the further info. I think I will get one as a portable practice pad :D 8-)
Adam :D
ABigPancake
Postby freshnelly » Wed Feb 19, 2014 8:11 pm
That is so funny! I have just pulled mine apart, searched for the processor and ended up here! I've just put mine back together, no point as your insight is great!
I'm trying to figure out how to add a MIDI program change to control the wheel remotely, but because the unit stays on the last setting on power up, if things got out of sync, it'b be useless. I thought about siphoning data off the LCD to read the "Exx" or "Ixx" number on the screen, but it seems to be an embedded driver so that could be a bit more difficult. I suppose connecting a microcontroller to the reset combination that beats the MPX to the punch might work... to do a reset every time the unit is powered up.
Anyone have any thoughts?
I was amazed they hadn't included PC in the implementation :o
Added Feb 21st: I have posted a page on the MPX8's "Missing Notes" issue having solved it with some hardware I just designed. Also Doubles, or low velocity repeats has been solved. http://freshnelly.com/mpx8.htm
freshnelly
Postby DX21 » Sat May 17, 2014 9:43 am
freshnelly wrote:That is so funny! I have just pulled mine apart, searched for the processor and ended up here! I've just put mine back together, no point as your insight is great!
hmmmmmn maybe I can add a bit of fudge to the GPIO routine... so it doesnt pick up debounce or shitty hits.
PREPARES COFFEE
~Time Trax~
DX21
Real name: Fender
Gear: Yamaha DX21
Kawai K3
Band: AHHHH!?!!?
Postby DX21 » Mon Dec 15, 2014 6:16 pm
Watch on youtube.com
Here's me using the MPX8 as a game controller for In The Groove 2 (Like Dance Dance Revolution)
It's super accurate and I used Bome Midi Translator Pro
Here's the button settings, the top ones are now set to the Start, Back, Coin and FastForward buttons, which are set up similar to the arrows.
For you DDR Nerds: This doesn't suffer from the Axis problem at all as each button is its own midi signal.
~Time Trax~
DX21
Real name: Fender
Gear: Yamaha DX21
Kawai K3
Band: AHHHH!?!!?
Postby DX21 » Sun Jan 11, 2015 7:29 am
Adam :D
Good news on this front, I took a trip to the dollar store to get myself a little AA Battery powered USB backup cellphone Charger, out of curiosity I plugged it into my MPX for science purposes....
The drum machine itself draws a good 500mA which will unfortunately eat anything but the strongest NiMH Rechargables.
I'd say a pair of 2500mA Energizer NiMH batteries Should in Theory give a few hours of use.
This won't work for very long with standard Alkalines due to the power draw.
The consistent power drain may cause Lithium's to become very warm in some cases (as lithium's are designed to be used in bursts, like in cameras, or flashlights)
but here it is, living on a pair of dollarstore alkalines, which lasted approximately a whole 30 minutes :P
~Time Trax~
DX21
Real name: Fender
Gear: Yamaha DX21
Kawai K3
Band: AHHHH!?!!?
Return to Samplers
Users browsing this forum: miserablism and 4 guests
